Import LT program to d::light
  • guigelabert
  • Auteur du sujet
il y a 14 ans 8 mois #4247 par guigelabert
Import LT program to d::light a été créé par guigelabert
Salut companys!
Could anybody explain me how can I import files from LT Lighting console?
I can save files as *.lt file and also as *.txt file (when I save as ASCII file), but not as *.asc.
Thank you very much
il y a 14 ans 8 mois #4248 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Re: Import LT program to d::light
it should be possible, can you post a .zip of one example?
  • guigelabert
  • Auteur du sujet
il y a 14 ans 8 mois #4249 par guigelabert
Réponse de guigelabert sur le sujet Re: Import LT program to d::light
Here you are!
I add an *.lt file and a *.txt file of the same show.
Those are the 2 possibilities I have in my console.
Thank you very much Nico.
:woohoo:
il y a 14 ans 7 mois - il y a 14 ans 7 mois #4251 par dFVarela
Réponse de dFVarela sur le sujet Re: Import LT program to d::light
The *.txt file seems to be exactly like a ascii file just open it and save it as a *.asc file, that should do the trick!
If you are using windows do it whit notepad++ and not whit notepad!
dFVarela
Dernière édition: il y a 14 ans 7 mois par dFVarela. Raison: I've converted it to *asc, try this attached file!
  • guigelabert
  • Auteur du sujet
il y a 14 ans 7 mois #4252 par guigelabert
Thank you very much.
One last question: how can i convert it with Mac?
Thanks again.
il y a 14 ans 7 mois #4253 par sl1200mk2
@guigelabert,
on Mac, i use TextWrangler to edit all sort of text...
As Daniel mentioned, it looks like exactly .asc files. (he did for the job for ya man!!)
however, times are just mark as 'UP'. you won't have down times...
tell us how it goes,
  • guigelabert
  • Auteur du sujet
il y a 14 ans 7 mois #4256 par guigelabert
Thank you very much, men!
I'll try and i'll tell you how it works.
il y a 14 ans 7 mois #4257 par dFVarela
That trick it's used between CONGO & MA LIGHTING, one uses *.asc files and the other uses *.alq, so chanching the extension it does the trick!
dFVarela
  • guigelabert
  • Auteur du sujet
il y a 14 ans 7 mois #4270 par guigelabert
Hey everybody!
It works!!
It just don't respect the delay times, but I think it's usual in this kind of convertions, isn't it?
Thank you very much to all of you from Barcelona.
See you soon.
il y a 14 ans 7 mois #4273 par dFVarela
Yes, it is. When you import ASCII there are always times that don't work properly!
dFVarela
Temps de génération de la page : 0.170 secondes
