'Enter' for level, keypads and shortcuts
  • homesepia
  • Auteur du sujet
il y a 16 ans 5 mois #1123 par homesepia
'Enter' for level, keypads and shortcuts a été créé par homesepia
bonjour, I've read something in the forum about shortcut on 'enter' key and keypads (i'm slowly learning french with DL forum but I'm not so sure if I catch the right meaning...)
so, maybe it helps:
I use the shortcut 'Return' for 'at level' (is it the 'enter' key? anyway, the big one on right side) it works ok and is much friendly for programming
I use a belkin numeric usb keypad for typing channels, levels, etc, it's much faster than macbook's clavier. It has also the 'enter' key. And 'num lock' key to change between numbers and function keys, so with this I have also keys for record, modiy, etc.
I use the aplication 'keyboard maestro' (macOS, don't know if for PC...) to remap keypad keys to the computer keys I use for DL shortcuts, so no need to change DL shortcuts when using the keypad ( keypad keys has different names, 1 is KP_1, etc ). So I put * key for channel, / key for thru, etc.
before I understood this and found this program I was going to put the f** keypad (I bought it for DL use) in a microwave to make a nice pizza. This program also allows to assign a keychain to a key...
salut
Temps de génération de la page : 0.106 secondes
