- Remerciements reçus 1071
adventures with RaspberryPi 4
www.raspberrypi.org/
L'idée est de produire un paquet (.deb) pour que
:Light puisse fonctionner sur ce matériel.au premier démarrage du Pi, j'ai suivi ces étapes pour le mettre à jour:
STEPS
Follow on-screen instructions until the prompt for input is reached.
Instead of doing, I believe the usual sudo apt-get update && sudo apt-get upgrade -y
DO sudo apt update -y
THEN when complete, do reboot followed by the usual sudo apt-get update && sudo apt-get upgrade -y
THEN when complete, do reboot followed by the usual sudo apt-get dist-upgrade -y
super, le Pi est à jour...
more to come
- Poypoy
- Remerciements reçus 22
quand ça sera ok je vous le dirais
- dFVarela
- Remerciements reçus 5
What's the monitor that you are using?
dFVarela
dFVarela
it's a microHDMI monitor... nothing fancy here...
- dFVarela
I've not made the question properly...What i'll be the minimum resolution?
Being able of using the raspberry pi touch screen would be great! :woohoo: :woohoo:
dFVarela
I'll launch the pi4 and tell you the minimum resolution... but I think it's more or less 800x600.
so I doubt it'll fit with the pi touch screen
1280x864, otherwise, you won't get the whole window
by the way it works great
does someone have a pi4 for testing?
- dFVarela
The pi monitor is 800x480...1280x864, otherwise, you won't get the whole window
Not yet... Next week i'll be in Dublin, but when get back home i'll be buying one, 4Gb i think that's what you'll be recomending!does someone have a pi4 for testing?
Just 2 questions:
Are you having problems with the heat?
Do use a RTC?(or advive to use one!)
dFVarela
dFVarela
the raspbian fit on 16GB microSDNot yet... Next week i'll be in Dublin, but when get back home i'll be buying one, 4Gb i think that's what you'll be recomending!
not when outputting DMX thru wifi (via sACN).Are you having problems with the heat?
I didn't check with usbDMX.
no... I think the more generic it's the better it'sDo use a RTC?(or advive to use one!)
a runnning chaser over 512 channels (each together fading from 0 to FF) consume 9% of the CPU.
easy for the pi
- dFVarela
I meant 4GB ram, or is the 1GB ram enough?the raspbian fit on 16GB microSD
The only problem of not using a RTC is you will always have to connect to internet in order to have date/time set correctly!no... I think the more generic it's the better it's
dFVarela
I've the 4gb one.
About the RTC, in DL point of view you'll need internet connection for licence activating/deactivating and every 3 month.
Apart from that, no need for internet so not really for for an rtc kernel.
My thought is that DL needs to run on a generic raspbian for anybody to use it without pain. If you decide to run it with arch, send me your distribution and I'll compile all libraries for DL to work.
I think it's a nice addition to supported platforms....
- dFVarela
dFVarela
