4.0.12 changelog
il y a 9 ans 7 mois - il y a 9 ans 7 mois #14586 par sl1200mk2
4.0.12 changelog a été créé par sl1200mk2
-new 'NoSolo' option for submaster:
it means that a submaster tagged as 'NoSolo' won't be closed during 'Solo' operation, it also means that it won't close any sub when it's flashed.
you just need to clic 2 times on the solo option .
-when 'Solo' operation , device's parameters are now untouched (except the INTENSITY/DIMMER parameter)
-new 'ReSync' option for midi:
this function resend all midiOut levels. it's useful when you switch preset from the BCF2000
-new option in the SETUP to bound MLink time and Timed submasters to Joystick:
it means one can now speed up or down submasters opening/closing
-import Sample extended:
you can now select in one shot several samples to import.
-'clone' is now available in the sample editor B) :
it means you can copy selected channels levels to other(s) channel for a defined region or for a frame. This let you create enveloppe for channel and copy it to other channel.... yeah I know, this is huge!
-import Chaser extended:
you can now select in one shot several chasers to import.
Temps de génération de la page : 0.107 secondes
