x-fader 16bit resolution in OSC
- stebian
since your software allows controlling 16bit LED's and I almost exclusively use the OSC x-faders to move from one cue to another, it would be useful to have the same resolution here. Do you see a way in implementing that?
stephan
- Remerciements reçus 1074
it could be possible but not in a near future...
another thing, as you use OSC to control stuff, are you aware of the two first commands listed here:
getdlight.com/wiki/index.php/OSC#Syntaxe...n_4_.5B2018-02-01.5D
did you tried them?
another OSC command that I've forget to document anywhere is :
/deviceParameter/COLOUR/RED [0.0...1.0]
it works for selected devices.
in the setupI/O you can choose if /deviceParameter act as relative or absolute mode.
absolute == [0.0...1.0]
relative == -1/+1
as for 4.1.04_b10 absolute works fine, relative never do the -1... I'll fix that
and for the next beta/release, I've reworked /pad/freescale to accept float or int arguments. This message is designed to increment or decrement levels of selected channels (and so INTENSITY/DIMMER for devices)
- stebian
And yes, I know these commands. I still need to integrate them in the device wheels on the controller…
I use another wheel which makes use of /pad/freescale, so I will be happy about float arguments on that one.
Thank you, Nicolas!
stephan
- stebian
did you change /pad/freescale in 4.1.04_rc1?
I doesn't work here. I was curious to check on sending floats but that did't do either. I tried /pad/freescale +0,1/-0.1
stephan
yep I did change it but apparently not in a good way...
range for float is 0.0....1.0
next week I'm on tour, I'll be able to double check on Friday...
- stebian
When you say range for float is 0.0....1.0, do you mean absolute or relative? Can I even send /pad/freescale 0.01/-0.01 as it works for devices?
Have a good tour!
stephan
the proposal for /pad/freescale is :
whatever value you receive you store it
-if next value is >, increment selected channels
-if next value is <, decrement selected channels
so there's no range...
tell me if it's acceptable for you?
- stebian
- stebian
thanks for the release.
pad/freescale works neither for ints nor floats. It did for a moment on absolute floats only and then it stopped.
stephan
testing the /pad/freescale here with pureData and it's fine.... so there's must be something somewhere...
pureData is sending message like that:
/pad/freescale f 100 (100 is for example)
on the first time DL is receiving freescale it visually does nothing as the first value is used to set the zeroPoint.
next call by pureData is :
/pad/freescale f 101
DL now knows it should increment so selected channels are processed +1 (not +1%, but +1 in realValue).
where does it fails for you?
- celio
- Remerciements reçus 72
My setup on Touch osc is an Encoder with message /pad/freescale and value range from -1 to 1
All works fine with previous version.
Maybe on the new version i need to update the value range.
- celio
Isadora receive midi from controlleur and send to dlight : /pad/freescale with range from -1 to 1
For several reasons I would like to avoid the former-1/+1 range
- stebian
@celio
You probably have the same issue as me then...
stephan
Are you using pureData?
The f or i is needed when using the sendtyped message to packOSC
