- Remerciements reçus 958
adventures with RaspberryPi 4
- Administrateur
it's a microHDMI monitor... nothing fancy here...
- dFVarela
- Membre premium
- Remerciements reçus 5
I've not made the question properly...What i'll be the minimum resolution?
Being able of using the raspberry pi touch screen would be great! :woohoo: :woohoo:
dFVarela
- Administrateur
I'll launch the pi4 and tell you the minimum resolution... but I think it's more or less 800x600.
so I doubt it'll fit with the pi touch screen
- Administrateur
1280x864, otherwise, you won't get the whole window
by the way it works great
does someone have a pi4 for testing?
- dFVarela
- Membre premium
The pi monitor is 800x480...1280x864, otherwise, you won't get the whole window
Not yet... Next week i'll be in Dublin, but when get back home i'll be buying one, 4Gb i think that's what you'll be recomending!does someone have a pi4 for testing?
Just 2 questions:
Are you having problems with the heat?
Do use a RTC?(or advive to use one!)
dFVarela
dFVarela
- Administrateur
the raspbian fit on 16GB microSDNot yet... Next week i'll be in Dublin, but when get back home i'll be buying one, 4Gb i think that's what you'll be recomending!
not when outputting DMX thru wifi (via sACN).Are you having problems with the heat?
I didn't check with usbDMX.
no... I think the more generic it's the better it'sDo use a RTC?(or advive to use one!)
a runnning chaser over 512 channels (each together fading from 0 to FF) consume 9% of the CPU.
easy for the pi
