adventures with RaspberryPi 4
3 years 7 months ago #19043 by dFVarela
the raspbian fit on 16GB microSD
I meant 4GB ram, or is the 1GB ram enough?
no... I think the more generic it's the better it's
The only problem of not using a RTC is you will always have to connect to internet in order to have date/time set correctly!
dFVarela
3 years 7 months ago #19044 by sl1200mk2
About the RAM, yeah I realised after more readings what you were talking about.
I've the 4gb one.
About the RTC, in DL point of view you'll need internet connection for licence activating/deactivating and every 3 month.
Apart from that, no need for internet so not really for for an rtc kernel.
My thought is that DL needs to run on a generic raspbian for anybody to use it without pain. If you decide to run it with arch, send me your distribution and I'll compile all libraries for DL to work.
I think it's a nice addition to supported platforms....
3 years 7 months ago - 3 years 7 months ago #19046 by dFVarela
Got my PI today, if you need testing...
dFVarela
Last edit: 3 years 7 months ago by dFVarela.
3 years 7 months ago #19047 by sl1200mk2
héhé...
I'll send you a test version next week when I'll be at home
cool, thanks Daniel.
3 years 7 months ago - 3 years 7 months ago #19053 by dFVarela
For now i'll stay whit raspbian (Raspbian Lite as nice possibilities), it's a solid platform... Maybe after some work i'll return to arch!
I'll be on tour but maybe i can test it in Toulouse! :evil: :evil:
And yes, i'm using my new RPI to post...:woohoo: :woohoo: :woohoo:
dFVarela
2 years 4 months ago #21000 by kevind
Salut, je viens d'installer la version 4.1.15 sur un raspberry pi 3B tournant sous raspberry pi OS (version de décembre 2020).
Apres quelques tests avec du trad et des lyres,tout semble fonctionner correctement.
Voici quelques bugs rencontrés :
- le pavé numérique du clavier ne fonctionne pas dans les "barres d'entrées" du pad, de la conduite principale, du patch et toutes les autres
mais fonctionne sur l’édition du nom d'un chaser par exemple. la petite console en haut à droite du pad dit que le raccourci n'existe pas.
- dans le device commande, si l'on click sur le bouton Lee de l'onglet couleur, la palette s'affiche mais ne disparaît pas si l'on change d'onglet (focus par exemple) sans sélectionner de couleur.
j'aurai bientôt un pi4 afin d'avoir 2 écrans, s'il faut tester la 4.2 ou d'autre, pas de souci, le temps ne manque pas et les événements c'est pas encore :)
Time to create page: 0.435 seconds
