- Remerciements reçus 988
problem with cue order in sequence
- homesepia
- Visiteur
il y a 14 ans 7 mois #975
par homesepia
Réponse de homesepia sur le sujet Re:problem with cue order in sequence
merci four your time, I will try downloading new DL and starting all from begining...
- Administrateur
il y a 14 ans 7 mois #976
Réponse de sl1200mk2 sur le sujet Re:problem with cue order in sequence
i'm absolutely confused.....
- homesepia
- Visiteur
il y a 14 ans 7 mois #977
par homesepia
I found it !
That happens when there are no more empty steps in secuence.
For creating a new show, I use to open an old one and erase all FXs, groups and steps. By this way I keep shortcuts and background color, and each new cue I record DL loads on a new step. But then when re-opening the show and adding new cues, it keeps always the last step on last position and adds the new ones before that.
I see that when making a new show, there are 20 empty steps at the begining and DL automaticaly adds an empty one each time a new cue is recorded. In this case, there's no problem with cue order.
You can try it recording for example two cues in a new show, deleting then steps 3-20, saving it, closing and re-opening it and then trying to add new cues.
Hope it helps...
salut
Hope it helps...
salut
- Administrateur
il y a 14 ans 7 mois #978
bien joué, i would never find it by myself !!!
- bdt
- Membre junior
il y a 14 ans 6 mois #1010
par bdt
Réponse de bdt sur le sujet Re:problem with cue order in sequence
Hello
Yes I have the same problem.
When I record a new Cue, it is automatically inserted at a wrong step in the sequence.
I have to remove this step, go to the right place, and then insert a new step and affect the new Cue.
Salut
J'ai le même probleme.
Quand je crée un nouveau Cue à un endroit donné dans ma conduite, DL l'insère automatiquement ailleurs (hier c'était sur mon Step 12 systématiquent).
Il fallait que je remonte à cet endroit (Step 12) pour l'effacer, puis revenir là où j'en étais, inserer mon step et y affecter mon Cue.
Macbook C2d, OSX 10.5.8, DL2.2, Enttec USBDMX PRO.
Salut
- Administrateur
il y a 14 ans 6 mois #1011
as-tu essayé avec la 2.3 ?
Temps de génération de la page : 0.296 secondes
