BCF2000 - move faders when changing submaster page
1 year 3 months ago #25929
by mjodar
marc
BCF2000 - move faders when changing submaster page was created by mjodar
Hi Nico and friends!
A friend gave me a Behringer BCF2000, and i want to try and use it with Dlight. I already have a Nanokontrol2, but I like the idea of the faders moving when I navigate through Submaster pages.
I can program the BCF (through the console itself, change CC, command number....) or the editor. That's no problem
But I want to know if there's a way when I change submaster page, Dlight sends a MIDI command of the state of all the Submasters, so the BCF updates the position of the faders.
I have the Midi input of the faders patched as SubStick, so fader 1 responds to the 1st sub of any page, the 2nd fader responds to the 2nd sub, etc.
My other idea was to program lots of diferent presets on the BCF. All the presets with the same configuration for the buttons and encoders, only changing the CC number for the faders (preset 1: faders CC 0 to 7 / preset 2: faders CC 8 to 15 / preset 3: faders CC16 to 23 ...... and so on). Then I would navigate through the presets of the BCF, in order to change Submaster pages.
But I think is a tedious and a lot of work, only if DLight is able to "flush" all the submasters state when I change page.
Hope it all makes sense...
Thanks a lot!!
Thanks a lot!!
marc
1 year 3 months ago #25934
Replied by sl1200mk2 on topic BCF2000 - move faders when changing submaster page
Hi,
DLight flush submasters's state when you change displayed page if they're patched to a MIDI message.
Hope it helps.
Hope it helps.
1 year 3 months ago - 1 year 3 months ago #25951
by mjodar
marc
Replied by mjodar on topic BCF2000 - move faders when changing submaster page
Hi Nico,
I'm really sorry, but then I don't get what I'm doing wrong. Can you please help me? What do I have to do to make the faders move when I change Sub Page?
Thanks a lot!
Thanks a lot!
marc
Last edit: 1 year 3 months ago by mjodar.
1 year 3 months ago #25952
Hi,
first thing I would do is to update DL.
then I would install Protokol hexler.net/protokol in order to be sure of what kind of Midi messages DL send when you change the submaster's page.
to be continued
to be continued
1 year 3 months ago #25953
by mjodar
marc
Okay, so updated to last version. With the previous version, looking on Protokol, DL was not sending any MIDI data when moving submasters.
Now, having the VirtualMidi Output enabled, DL sends MIDI data when moving faders (same message as the BCF is sending)
This screenshot above is when i move a fader, DL replies with the same message
This screenshot above is when i move the sub on DL
But, still the faders are not moving.
I know they work because when i change between presets on the BCF they move. I tried with the three modes for the motorized fader on the BCF (move, pick-up, motor)
marc
1 year 3 months ago #25954
so, as shows Protokol, DL is sending MIDI when you move the faders.
so now there's two more things:
-either DL does not send to the good Output. did you tried to set only the BCF2000 port 1 as Output?
-either the BCF is not in a mode where it can receive MIDI
Time to create page: 0.359 seconds
